Hi
Is there away to take screenshots of an AVI? Ive tried using the normal method (Press screen > paste) but it doesnt work!!!
Any ideas?
VirtualDubMod - Make sure it's the MOD one. There's an option to snapshot the frame to a jpg or png.
You can do it with Virtualdub under 'Video' > Snapshot or Copy source frame.
EDIT: Sorry, VDMOD. -
Thanks, managed to do a few files.
But some I get:
"Could'nt locate decompressor for format 'DIV3' VirtualDUB requires a Video
for Windows compatible codec to decompress video."
Any ideas? -
Try MPC
It doesn't have to be VirtualDubMod. Any VirtualDub program will do it.
Open file
Video - Copy source frame to clipboard or Copy output frame to clipboard
Open any graphics editing program ( Paint, Photoshop, Irfanview etc...) and paste.
I like to use Irfanview to view video directories and save frames myself. That way, I don't have to keep opening files in VDub to see what they are.
The file you are trying to open is a DivX low motion file.
ScreenShot
By drgt in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2010, 14:10 -
Taking 731 mb .avi and burning it to a 4.7 dvd? possible?
By BroCraig in forum Authoring (DVD)Replies: 10Last Post: 16th Aug 2009, 22:55 -
Video screenshot help
By KateP in forum Newbie / General discussionsReplies: 9Last Post: 27th Apr 2009, 01:39 -
Settings Correct? Taking a Long Time/.avi to DVD
By 5Buffalo in forum ffmpegX general discussionReplies: 3Last Post: 24th Dec 2008, 14:29 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 10:26
