Just got a new PC, installed WinDV but I am unable to tranfer AVI files back to camera..The message that comes up that says,
"Error:Error"
Why is this happening?
Results 1 to 9 of 9
Lucky
Will it transfer the other way?
What is the file you are sending? Its origins and codec.
Are you sure the file is DV format?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
It tansfers other way
Sending DV made using Ulead Vide Studio
Yes, DV Type 1 and I tried type 2Lucky -
Originally Posted by Lucky_9
In the past I've routinely converted MPeg2 and other formats to DV for playback off the DV camcorders and never had a problem using Vegas, Premiere or ULead.Recommends: Kiva.org - Loans that change lives.
It finally works...I downloaded the Ace Mega codecs packa dn know I am able to transfer from PC TO Camcorder
Lucky
Should I use WinDV?
By tygger in forum Capturing and VCRReplies: 19Last Post: 6th Jan 2012, 17:23 -
Windv to harddrive
By runnernorth in forum Capturing and VCRReplies: 3Last Post: 12th Jan 2010, 04:36 -
WinDV
By kippard in forum Capturing and VCRReplies: 3Last Post: 7th Apr 2008, 23:43 -
Windv Scheduler
By ScottEslick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Jan 2008, 21:46 -
Error with WinDV ?
By Zhuge Liang in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th Jul 2007, 02:47
