First post here and hope this is the right place, and hope I will be making sense. I apologize in advance for my apparent ignorance.I have a short film that was originally widescreen, but had been converted to fullscreen without cropping the sides when made into an AVI. Thus, the image is "squished" in from the sides. I downloaded the trial versions of Premiere Pro 1.5 and Encore 1.5, and think they have the capability, but I'm not sure how to do it. I also have a trial of TMPGEnc and Virtual Dub, if those would be better choices.
ALSO, if I did successfully convert this film, would there be black bars top and bottom if viewed on a widescreen TV/monitor? Thanks all,
Al
Virtualdub resize filter. Keep the horizontal as-is (ie. match the current resolution) and reduce the vertical until it is correct.
Read my blog here.
I just now found and used that filter. Thanks for the help! BTW, I'm guessing I should resize the image then have black bars so it can be watched on a 4:3 tv, correct? Now, if I were to take it to my dads and play it on his widescreen TV, would it then be "squished" horizontally, black bars and all?
Are you making a DVD? Just take your original AVI file and convert it to MPEG 2 as-is. But specify that it is anamorphic 16:9. Burn it to DVD with DVD mastering software that supports 16:9. When your DVD player plays it back it will handle 4:3 and 16:9 displays appropriately.
quartermiler1320 :- Not necessarily - it will probably be bordered all round, so you would have to zoom it in. If you are playing it back on a Divx enabled DVD player, or a PC, then it should not be an issue, as the player should deal with the resizing and aspect ratio itself.
Read my blog here.
What codec did Adobe Premiere Pro originally use, and...
By Cyrax9 in forum MacReplies: 1Last Post: 4th Sep 2010, 16:17 -
Fixing Speed of Video (originally film)
By mark23 in forum RestorationReplies: 1Last Post: 2nd Jan 2010, 14:59 -
Can I convert an avi back into a DVD and restore original quality
By Vidonizer in forum Video ConversionReplies: 1Last Post: 11th Nov 2009, 15:32 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 19:55 -
Can you convert an AVI encoded with Xvid to one with a Divx codec?
By Timfoxx in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 23:53
