Hello everyone, between the NEC 3520 and NEC 3500 what would you guys pick? Is the speed ripper unlocker availiable for both models? What NEC model would give me the least trouble? Thank you for your time.
Results 1 to 9 of 9
The 3520 does DVD-R DL
If you need a high speed ripping drive, get a DVD-ROM, don't prematurely kill the burner from overuse.Want my help? Ask here! (not via PM!)
Oh ok, as you can tell I'm a noob at this. But riddle me this, is there such thing as a firmware or patch that can increase the recording speed of the dvd burner? And it does, are they availiable for the NEC models?
With relatively high-speed ripping DVD burners for ~$50, does it really make sense to buy a DVD-ROM drive anymore???
I don't think so. YMMV. -
Which DVD-ROM do you reccomend? What speed may be possible? -
My NEC 3520A plays badly scratched and difficult discs which my DVD-ROM (andother burner) can't handle so it's now my main drive as well.
You might want to look into the 3540. Its relatively new on the market but it's already a solid choice. The firmware is newer than the 3500 or the 3520 but from what I've heard it's had less initial issues than either of them did in their early days.
Originally Posted by rfielder
The Pioneer DVR-A08XLA will rip DVD-Video SL/DL at 11.80X and 9.38X respectively. -
Another thing to consider... buy a DVD-writer and a DVD-ROM. Then you are increasing your ripping speed two-fold (if ripping two discs at once). I have a machine with three DVD-ROMs and a writer. I set four discs to rip and leave the room for an hour or whatever. Come back and it's done. It's a great alternative to speed wars between drives, budget permitting.
Best of Luck,
-Evan-
Guide to fix Illegal Disc Error for NEC drive (possibly others)
By lucaschrist in forum DVD & Blu-ray WritersReplies: 10Last Post: 5th Apr 2008, 01:11 -
NEC AD-5170A Questions
By urb1972 in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Nov 2007, 20:39 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 21:07 -
NEC 4571A problem
By rmorrison1 in forum DVD & Blu-ray WritersReplies: 18Last Post: 1st Jul 2007, 12:35 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 19:05
