  1. Hi Chris
    i downloaded / installed the svcd2dvd from the users area
    the menu item fix worked ok
    but now the program wont burn to disc
    but if i right click the VIDEO_TS i can burn useing your nero plugin
    nothing in log file
    14:54:28:
    DVD Folders: Processing D:\Program Files\BadgerIT\SVCD2DVD v2\menu\menu.mpg...
    14:54:35:
    14:54:36:
    14:54:36: Finalising DVD...Done
    14:54:36: Done: Authoring DVD Folders
    Burning DVD folder
    just keeps saying not responing .
    i did set the burner in the settings too
    might be a 1 0ff
    yours brit
  2. just done 1 more same thing
    you broke it again or is it me lol
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Is anything else open which may be "locking" the DVD drive? Like Nero or Neroburner? If you reboot & just try the _s2d files from the same project in a fresh run, does it burn?
  4. nope that 2nd try was after a reboot
    ? is anyone else haveing the problem 2
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Do you get the NeroBurner popup?
  6. ok sorted
    uninstall. reinstall svcd
    reinstall nero
    reboot
    now a ok thanks for the help
    yours brit great program
