I would like to take a stereo wav and encode it for a dvd so that it plays in prologic. Can this be done with besweet? If so, how?
No. Prologic is an analogue signal, and requires correct mixing as well.
That said, put any stereo audio through a Prologic II amp (and to a lesser extent, a standard Prologic amp) and you will get rear speaker activity. PLII can do a pretty good job with non-PL tagged audio.Read my blog here.
Thanks for the info. When I convert the wav should I convert it to ac3 or mp2 in order to get the best pl2 sound out of my receiver or does it matter?
It doesn't really matter, although I know the AC3 encoder that ships with Vegas allows you to flag a stereo AC3 as Pro-Logic, even though there is no extra encoding done. It shows up as a forced rear speaker on your amp display.
I would use AC3 for universal compatability. MP2 may not play in all players.Read my blog here.
5.1 with stereo won't export to 5.1 WAV in Premiere
By koberulz in forum AudioReplies: 0Last Post: 15th Jan 2012, 12:19 -
I keep losing stereo audio on my stereo bluetooth headphones (vista)
By yoda313 in forum ComputerReplies: 0Last Post: 30th Jan 2010, 09:19 -
stereo loss after converting from wav to ac3
By Driber in forum AudioReplies: 8Last Post: 9th Sep 2009, 02:29 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 09:33
