ok,
i am trying to make an mp3 (for ringtone) of some clips off of Chappelle's show dvd...
howver, i want to remove the laughter in the back ground and just keep his voice...
the problem, unlike a "hiss" is that the frequency of the laughter changes; certain parts are very high e.t.c..
i've played around with Adobe Audition but couldnt remove it that well..
does aybody know what settings to use to get the opposite of "vocal remove"?
i did the vocal remove and got a good sample with just the laughter....
if there is some way to do the reverse, it should be ok...
Won't happen.
Copying "Rango" and similar DVDs
By dphirschler in forum DVD RippingReplies: 14Last Post: 22nd Nov 2011, 03:03 -
Looking for a video editing feature similar to "Shadows/Highlights" from PS
By vitwa in forum EditingReplies: 5Last Post: 6th Mar 2010, 17:21 -
Removing bad segments using program "Video Edit Master"
By risp73 in forum Newbie / General discussionsReplies: 0Last Post: 30th Aug 2008, 15:52 -
Removing "packed bitstream" from .avi loses chapters?
By louv68 in forum Video ConversionReplies: 2Last Post: 3rd Mar 2008, 11:47 -
Problems with removing "Piracy is theft" sequence from 24 season
By Hamilton in forum DVD RippingReplies: 2Last Post: 10th Jan 2008, 20:25
