Hi when I try converting my avi file the finish product does not have any sounds. Oh, I use TMPGEnc 3.0 Xpress. When playing it in the media player there is sounds. So I went to look for the answer my self. I found out that the audio format can be AC3 and TMPGEnc does not support AC3. So I use Virtual Dub, and I even install AC3 decompressor. I succesfully converted the audio file to wav. Then I open the avi in TMPGEnc and the new wav file for it to convert. But there is still no sound when I try playing back the converted file. What do I do???? Please help. Thanks in advance.
Can you open your converted file in GSpot (you'll need 2.52 Beta for MPEG files), take a screenshot and post it back here ?
This guide may assist you with your screenshots
If in doubt, Google it. -
OMG!!! I did it. Thankyou guns1inger. At frist I had no clue what you mean. Then I started to mess around and it work. I am so happy right now. Thankyou.
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 09:27 -
Getting Audio before TMPGEnc?
By chronic777 in forum Authoring (DVD)Replies: 2Last Post: 5th Apr 2009, 07:52 -
TMPGEnc no audio
By jay_lubb in forum Video ConversionReplies: 4Last Post: 23rd Mar 2009, 11:16 -
No audio in TMPGEnc
By jay_lubb in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2009, 02:26 -
TMPGenc and audio file
By JosieB in forum Video ConversionReplies: 10Last Post: 27th May 2007, 04:33
