I have tested the Live function of the MH30 and I don't understand why it works so bad: Sometimes it is ok, but sometimes when I want to record something that has started on the TV, I rewind and I push record and the M30 blinks with LOADING on the panel control, then it stops !!! Someone has this problem ? Another problem, I've choose SP as rec mode, but when I start to record, it switches to FR65 !
The MH30 has good image, but it appears that it is the only one thing it has. All the rest is problems: bad interface, no more than 8 programs or index on a DVD, dubbing speed limit.
Results 1 to 9 of 9
https://www.videohelp.com/forum/viewtopic.php?p=890867#890867
Originally Posted by BaldrickIf in doubt, Google it. -
Edited. Don't do that again.
Oh, and the problem is likely bad media.
Sorry, I apologize, this MH30 irritated me a lot. I don't know if have a bad unit. For the dubbing speed problem, I know it has relation with editing. But if someone can say me why it's automatically switch to FR65 rec mode when recording (Live mode)?
You think that the HD has bad sectors (or something like that), and this is why the MH30 is blinking LOADING, then shutting down?Oh, and the problem is likely bad media.
Thank. -
Rewind?
The M30 shutdown, when, in live mode, I try to rewind then record. The screen say that the it will record, but it shutdown. But I remark two things: If the live memory starts less than, let's say, one minute, If I rewind then record, it starts recording in SP mode, but if I wait more than let's say 10 minutes to make the same type of recording, it's start in FR65 recording mode, and if i'm waiting even more, it's sure it crash and shutdown.
Dude!!!!!! you so kill me sometimes!!!!!!!!!!Originally Posted by jimmalenko
But you have WAY too much time on your hands :P
Need suggestions on JVC DR-MH30
By iamnotamused in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Sep 2010, 03:04 -
JVC DR-MH30 Broke I think. Any suggestions. Loading error.
By hutch642 in forum DVD & Blu-ray RecordersReplies: 26Last Post: 20th Aug 2010, 20:35 -
JVC DR-MH30 make or restore hd particion
By danilo_nop in forum DVD & Blu-ray RecordersReplies: 0Last Post: 29th Feb 2008, 04:01 -
JVC DR-MH30 Broke I Think Update.
By hutch642 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Dec 2007, 09:43 -
JVC 9911 SVHS to MH30 - audio
By quickpick in forum RestorationReplies: 1Last Post: 6th Aug 2007, 12:45
. But not in the ******* subjects.
