Hello Everyone,
I spent a good long time trying to figure out how to share the HP PSC 1210 on my network and finally found my answer. The drivers that come with the PSC models are strange creatures that don't act like the "normal" drivers we are used to..like you cannot change the port settings from USB to an ip address in the case of using a print server..etc.
In case anyone else here would like to know..You have to install the HP 3420 driver and share it out on the network. If you are using XP on your other machines then just go out to the printer in network neighborhood once you have shared it and connect. You can now print to your PSC 1210 over the network.
Results 1 to 1 of 1
HP PSC 500xi - Unidentified port/connector
By CobraPilot in forum ComputerReplies: 8Last Post: 28th Jul 2011, 19:41 -
Can't use one of my XP pc's on network (Network experts)
By neworldman in forum ComputerReplies: 5Last Post: 21st Jan 2011, 15:12 -
Using two routers on network... is it possible?
By neworldman in forum ComputerReplies: 10Last Post: 14th Jan 2010, 00:25 -
network expansion?
By Xylob the Destroyer in forum ComputerReplies: 10Last Post: 7th Dec 2008, 18:31 -
Network printer on separate network?
By Lucifers_Ghost in forum ComputerReplies: 7Last Post: 5th Dec 2008, 13:52
