I am trying to go from pal to ntsc on a dvd.I have this ISO file only in pal format.But first i must encode with Tmpgenc and it do not rconize a ISO file.So I guess I need to convert to a ts-vedio file. how is done and what
tools Thanks to all.
I have Dvd vedio files captured using ISO buster. But the audio I can't
seam to get.Tmpgenc won't reconize a tao file and right clicking in ISO buster for audio does not work.Also in the program svcd2 it only works for bin files.IS there a way to convert that iso file to a bin? Some one needs to make guide to go from ISO to ntsc from pal. thanks -
TMPGEnc won't recognize VOB files with AC3/DTS audio.
1.Use DVDShrink->File->Open Disc Image and select only one AC3 or MP2(not DTS) audio track with no subtitles->backup.
2.Use TDA or Nero Vision Express to convert and burn.
It would be easier if you had the ISO on a DVD because you could use DVDDecrypter and TDA.Another option is to get a multi-system DVD player if all you want to do is watch the video on tv. -
First Thanks for your help.
I have try all the programs.Still got the same thing, good audio but black and white vedio.
One question I have a panasonic dvd s35 and Toshiba 52M84 dlp Tv.
I found a Phillips DVD player that is multi system.But will the TV play pal
vedios. Thanks -
Your tv is fine.Originally Posted by Fisherqw
A true multi-system DVD player will play any DVD on any tv,look for "region free" and "built-in PAL to NTSC converter". -
Thanks Moviegreek.
What DVD player would you recommend? I found the phillips 642 that says it will play Pal/Ntsc for $56.00 at best buy, would that work?
I call Toshiba They said it is only ntsc. I am ready to give it a try and if it
doen't work return it. Thanks again
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
1080i .TS Video file to Blu-ray .ISO file Help !
By SiNnOFf in forum Authoring (Blu-ray)Replies: 19Last Post: 3rd Nov 2010, 14:12 -
ISO file bigger than original video_ts file.
By bbanderic in forum DVD RippingReplies: 8Last Post: 20th Feb 2010, 20:04 -
Why Does ImgBurn Only Sometimes Build an MDS File with ISO File?
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 14th Aug 2009, 00:36 -
convert iso file back to vob file
By cda62 in forum Newbie / General discussionsReplies: 2Last Post: 9th Jan 2008, 13:50
