Hello
I already had the Kazaa Lite Codec Pack, and uninstalled it so i could download and install the newest version (the mega one). After this i tried to play a .mpg video file using media player classic, and there was a problem. The audio was perfect, but the video was distorted and "moving slowly" for example freezing/stuttering at certain parts.
I tried to play another file this time an .avi and the same problem occured though there was some improvement. When this happened, i thought there must be a problem with media player classic so i used BS Player and the same problem occured again!
Could anyone help me out please
Thank You
Results 1 to 13 of 13
Install codecs on a need only basis. Codec packs will give you nothing but headaches.
ok i have done that but the same problem still occurs. i tried playing a number of video files in different media players and here's what happened:
windowns media player 7: video worked no sound
windows media player 9: nothing appeared
avipreview: nothing appeared
zoom player: sound was there, but problems with the video (like before) -
Clean your PC's registry and junk files ect.. with good software.The problems Codec Packs cause leave junk traces on your computer.
~Luke~ -
Try Codec Sniper, careful though. you don't want to remove what you don't need. It's good at identifying what codecs are installed on your system and will indentify ones with problems.
there were some broken realmedia codecs, i deleted them but the same problem occurs. i may re-install windows but right now i have found a utility called sherlock codec detective and see what it comes up with. BTW thanks for your help
ok just an update, i have used the sherlock codec utility and it found some invalid references. Should i delete these references?? I am not sure if or where they are on my PC and the codec utility does not provide an option for deleting. So can you tell me what files i should delete??
take a look at the following link to see what the results were:
http://img237.imageshack.us/img237/8956/codec4os.jpg -
i can't delete the references using that utility (sherlock...)
could u tell me what files so i can delete them manually
Viewing YV12 images and videos, cutting a frame
By Festivas in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2010, 05:51 -
converting rotated ipod videos for pc viewing
By bkallsen in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2010, 16:59 -
Viewing Downloaded Videos Seeking Problem
By imdaman in forum Video Streaming DownloadingReplies: 2Last Post: 30th Nov 2009, 00:13 -
Help Viewing Videos
By Demonolith in forum Newbie / General discussionsReplies: 2Last Post: 11th Jul 2007, 11:03 -
problems viewing videos
By loa909 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jun 2007, 10:15
