Can someone tell me how I can crop video?
I've asked before and was told I could use Virtualdubmod.
Unfortunately, I have raw DV footage.
Virtualdubmod doesn't seem to be able to read the file.
I can load the file in other video editing programs, so I assume it can't be a case of not having the correct video codecs?
I don't want to compress the video to another format as the video is of poor quality in the first place... compressing to another format degrades my picture quality.
Thanks.
OM
Some "flavours" of virtualdub have had trouble in the past with opening up Type 1 DV-AVI, but I believe the latest versions (1.6.8 ???) can allegedly open type 1 without any hassles. Maybe try updating your virtualdubmod ?
If in doubt, Google it. -
Unfortunately, virtualdubmod doesn't seem to be updated anymore, although the original is. Have you tried installing the Panasonic DV codec ? I have no trouble working with DV footage in VDM using it.
Read my blog here.
i've got v1.5.10.1.
this seems to be the latest version available on the website?
any more ideas? -
The Panasonic DV codec will allow you to open and work with DV avi files in virtualdubmod. It's free, small, and will respect you in the morning. What more do you want ?
Read my blog here.
guns1inger
THANK YOU!
THANK YOU!
THANK YOU!
THANK YOU!
u just solved my problem.
i tried the panasonic codec...
and wow.
then used virtualdubmod...
wow!
virtualdubmode is soooo kewl.
and so damn powerful.
why was it stopped being developed?
How to crop a video?
By toqi786 in forum EditingReplies: 22Last Post: 27th Jul 2012, 21:37 -
Crop a Video
By jjis in forum EditingReplies: 3Last Post: 21st Jan 2012, 12:27 -
How to Crop Video
By xiaomanda in forum Newbie / General discussionsReplies: 6Last Post: 14th Jun 2011, 09:24 -
Crop a video?
By Cined in forum EditingReplies: 1Last Post: 29th Apr 2010, 07:50 -
Crop video
By weta in forum Newbie / General discussionsReplies: 10Last Post: 11th Aug 2009, 15:27
