Hi all, I have previously been using the following to do backups:
DVD Shrink (to shrink to hd)
ImgTool (to create iso)
DVD Decrypter (to burn to DVD)
Now having problems with protection errors in DVD Shrink.
Question: If I use DVDFab, to decrypt to hard drive, can I then put the files into shrink to reduce to fit on a 4.7GB disc? How do I do this?
Question: Are there any guides for DVDFab Decrypter, I find it difficult to follow.
It's not a Black and White world, to be alive the colours must swirl.
And I believe that maybe today, we would all get to appreciate.... The Beauty of Gray.
- Ed Kowalcyk (LIVE) - -
It's basically the same as using DVD DECRYPTER. All you need to do is guide DVD SHRINK to open up the files that you've ripped from DVDFAB. In other words instead of using the OPEN DISC in DVD SHRINK, you'll use OPEN FILES. Click on the VIDEO_TS folder that has the files you got from ripping in DVDFAB.
why are you using ImgTool to creat iso?
dvd shrink can output in iso.I love it when a plan comes together!
DVDFab 7 HD Decrypter
By burnmaster in forum Blu-ray RippingReplies: 3Last Post: 9th Apr 2010, 08:11 -
DVDFab Decrypter
By HacktheHacker in forum DVD RippingReplies: 11Last Post: 25th Feb 2008, 23:10 -
DVDFab HD Decrypter Issue
By adcmarti in forum DVD RippingReplies: 11Last Post: 27th Sep 2007, 23:24 -
DVDFab HD Decrypter???
By bltprf in forum Newbie / General discussionsReplies: 11Last Post: 9th Jul 2007, 00:09 -
problem with DVDFab Decrypter
By cmonzon in forum DVD RippingReplies: 1Last Post: 4th Jul 2007, 20:18
