I am looking for some software which works very much like Nero.
Reason being is that i have been having some problems with Nero on my pc and would like to try something else.
Any Recommendations?
Results 1 to 10 of 10
like nero in what way
nero tries to do so much
i would use media player classic if your looking for a software player -
ffdshow + haali matroska splitter + mediaplayer classic
for burning use Prassi
BHH -
EAC for ripping audioburnatonce for burning. Audacity for editing. DVDShrink for recoding DVD.Irfanview for editing pics. Media Player Classic for viewing video. DVDDecrypter for burning DVD use IMGTools Classic for making ISO for Decrypter.
~Luke~ -
I am basically trying to make a dvd data disc which contains say 5 divx films.
To make a data disk of divx files, you can use Folder2Iso to make an iso, and then use DvdDecrypter to burn the iso to disk. Both programs are freeware, and work perfectly.
You can use this guide to show you how to burn an iso with DvdDecrypter. Just skip the first part (where they are using ImgTools Classic to make the iso), and jump down to the second part, where it shows how to burn your iso.
The guide shows an older version of DvdDecrypter, but the 3 steps are the same. -
I also have a problem with Nero, sometimes leadout never finishes, I had to reboot the whole computer. Nothing is as good or as comprehensive as Nero. I have to use several software just to replace Nero. Previously I only need Nero but now I use alcohol for CD/DVD Duplication, Ashampoo or Recordnow DX 4.5 for Data Mastering and making a DVD video. I have Pioneer DVR109.
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
