Iīll try to explaine so ggod i can.....
1. I did rip the movie with Smartripper...
2. Then I did use DVD2AVI...
3. Now im about to encode the movie with TMPGEnc...
BUT....
I live in sweden and over here it is PAL, not NTSC, and i want to be able to get "real" widescreen.
So what should i do to get that ?
One more question.......
Should i be able to change the value for the "Aspect Ratio" under "Settings" then "Video" ???
If someone can try to help me, i can explane my problems a bit deeper
the DVD i did copy is 19:6 Anamorphic widescreen....
but when i have encoded it it gets in 4:3.....
I meen WTF is the problem there ???
Hope someone can help me.... -
You didn't say what program you are using but I'll assume TMPGenc. You also didn't say what template you are using, but I'll assume VCD_PAL.
Load the VCD_PAL template, load your D2V and wav source files. Click on settings:
Then click advance. Video arrange method: full screen keep aspect ratio, 16:9 625line PAL. (might want to make sure that it's also 16:9 under the main/source tab)
Encode. You can make a short test using the source range option to double check before encoding the whole MPEG. -
Yeah thanks....
I use TMPGEnc, and i trying to use the VCD Layer...
I can do everything but the last thing you said....
that i should make sure that itīs also 16:9 in the Main/Source.
If thats in the "Settings" "Video" then "Aspect Ratio"
then there is my problem.....I canīt change that value.
And it stands on 4:3 even cause i did copy a 16:6 Movie ???
I donīt really get that, but if you can help me a little more I might solve the problem...
16:9 Aspect ratio
By jeffh123 in forum Video Streaming DownloadingReplies: 5Last Post: 30th Aug 2011, 19:44 -
Aspect ratio help
By kkiller23 in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2008, 07:21 -
Aspect Ratio
By mistycat in forum Video ConversionReplies: 8Last Post: 8th Nov 2007, 02:43 -
Aspect ratio??
By frednufc in forum Video ConversionReplies: 1Last Post: 14th Oct 2007, 15:11 -
Aspect Ratio's
By AndySpring in forum Newbie / General discussionsReplies: 7Last Post: 23rd May 2007, 12:55
