oi
I just got hella dizzy searching fo' a specific guide cuz its just too many new info at once...
So maybe u guys could point me sum links in the right direction to this...
Need to burn a *.vob file(small one-100Mb) into a cd-r (and I have no dvd-writer)
ty
I do have cd writer..
Yeah, I wanna play it on my dvd player (Philips dvp642)
It does support vcd/svcd and raw mpeg
p.s I tryied to burn the *.vob as SVCD with nero... The image was ok but there was no sound...
Same happens when I burn it as data, no sound... -
The Philips 642 supports MPG ISO. So just burn the .VOB file onto an ISO data CD. You might have to rename it .MPG.
wow man, that was DOPE! \o/
I burnt as ISO like u said and didn't even had to rename it to .mpg....
Image n Sound both works good!
Thnx alot guys.... great help here.. -
ok, an issue
That 1st vob I tryied worked good, image and sound.
Then I tryied a new one... Image was perfect, sound didn't work. Renamed to *.mpg, same happend: no sound..
So is it like "normal" to happen when ya burn vobs? Sum of em just dont work smoothly?
I'll try another vob and hit back with sum logs.... ty -
ye ok, I tryied another .vob file...
image&sound are nice...(its stucked a bit on the begining, but i can ignore that, it was good overall)
So I guess I'll just have to burn and burn as much as I can so I can kinda identify a pattern why do sum vobs work great and some do not....
Maybe its the player that sux too, not sure of anything so far
ty once again.. -
I don't usually use CDs but I suspect the player may not spin them fast enough to read high bitrate VOB files smoothly.
I'm Not sure about the no-audio problem. You can always reencode the files to make standard MPEG files out of them. Using TMPGEnc for instance. Or you can use VirtualDubMPEG2 or VirtualDubMod to create Divx/Xvid AVI files.
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Burn .VOB File with .SRT to DVD+R DL (HELP!)
By holdenmcclure in forum Authoring (DVD)Replies: 2Last Post: 8th May 2008, 00:47 -
VOB to DV last VOB file finishes in about one second w/no data
By Gizmology in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2008, 17:39 -
Cutting .vob file in .vob format only
By rahul.never2far in forum EditingReplies: 11Last Post: 1st Oct 2007, 08:52 -
VOB DTS file to VOB AC3
By shanthaprasad in forum AudioReplies: 4Last Post: 25th Sep 2007, 13:34
