A friend recently got a new laptop and I've been helping him set it up. One thing we noticed is that when you put it on battery power the display darkens significantly. This makes it harder to view. Is there a way (in XP) to increase the brightness of the display when it is on the battery? He's not concerned about the shortened battery life as a result. BTW this is a Compaq Presario R4000
Results 1 to 12 of 12
Fn+F8
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
No, that raises the brightness of the screen. There's a seperate setting for when its plugged in and when its not. You'll have to change it by using Fn+F8.
If I'm on the battery and I use Fn+F8 to up the brightness will it keep that new level for subsequent times that I use the battery?
Yeah, it will keep that setting.
I looked in the Power Management settings in the control panel and I'm positive there is no section about the brightness control - I checked a couple times to be sure. Maybe I'm just missing somethingOriginally Posted by guns1inger
Same thing happens with my laptop. It gets brighter as soon as you unplug the power cord which seems backasswords to me. I've tried everything in Power Management too with no luck.
Its a Dell btw. -
I would try this Fn thing, I think it will work. If that doesn't do it for you then go with the BIOSOriginally Posted by adam
If you haven't tried it, go to Control Panel > Power Options > and set it to Home/Office Desk if it's set to Portable/Laptop. That usually cancels most power saving modes, including darkening the screen. You will dissipate the battery power quicker, though. That's the downside.
Some laptops have a seperate utility suite from the manufacturer that gives greater control than Window's generic tools. My Toshiba has a much more comprehensive power saving utility than windows, including screen brightness and a dozen other things.
Read my blog here.
Can I power an LCD TV with an external battery?
By Susannah in forum DVB / IPTVReplies: 10Last Post: 9th Nov 2011, 19:50 -
laptop battery question
By bballnut in forum ComputerReplies: 7Last Post: 30th Apr 2011, 13:07 -
Which to use on a Laptop, the Battery or Power Cord
By Moontrash in forum ComputerReplies: 4Last Post: 7th Jun 2010, 20:16 -
laptop + new battery = no Power
By nick101181 in forum ComputerReplies: 8Last Post: 15th Jan 2010, 14:29 -
laptop battery
By romanstopme in forum ComputerReplies: 7Last Post: 23rd Feb 2009, 04:03
