DVD Decrypter was unable to crack the CSS for this movie. Has anyone had any luck? or seen other movies with the same problem.
The funny thing is that the movie is not encrypted. DVD Shrink seems to work however.
Originally Posted by wolv6769
If it is not encrypted then there is no CSS to decrypt. What exactly are you trying to say?
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
You simply have acase where that particular disc simply will not rip! Dirt scratches, even invisible ones will somtimes cause a ripper not to rip. Does it play? on your pc? If it is not CSS encrypter than why in the world are you using a "ripper" to rip it? Just copy it directly it it to the HD as if it was data. If it does not copy then it is the disc.
No DVD can withstand the power of DVDShrink along with AnyDVD!
DVD Decrypter 3.5.4
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 9th Mar 2010, 14:48 -
DVD Decrypter
By Beaker14 in forum Newbie / General discussionsReplies: 17Last Post: 26th Oct 2007, 22:39 -
I am using DVD Decrypter
By Lissettep in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Oct 2007, 16:55 -
Help with DVD Decrypter
By Me-Hostage in forum DVD RippingReplies: 10Last Post: 20th Aug 2007, 08:12
