I have a sony dru 510a and I have been burning movies on it and I would be able to see all my movies on any of my dvd players at home fine. but last week I made a mistake on buying some dvd's 16x and now I can't see any of the movies on my dvd players.I look on my old dvds and they were 8x so I figured that is my problem now I don't know if the dru 510 cannot use the 16x dvds or if maybe I have to change the settings, when burning with the 8x I leave it at max speed. and I know the dru is only 4x write speed so anyway can anyone help me with this cause I have like 45 of these 16x dvds left.
Only thing I can suggest is to be sure you are using the latest firmware for your Sony burner. New firmware often have the latest media write strategys.
Good luck....
New to DVD movie burning - Help?
By dvdburning in forum Newbie / General discussionsReplies: 3Last Post: 10th Jan 2010, 23:51 -
Burning a movie to DVD
By johnnyo34 in forum Authoring (DVD)Replies: 6Last Post: 6th Jan 2010, 18:04 -
Burning DVD movie into CD R
By c1steady in forum Newbie / General discussionsReplies: 17Last Post: 8th May 2008, 14:17 -
Writer not burning at 16x like it should
By championjosh in forum DVD & Blu-ray WritersReplies: 7Last Post: 4th Mar 2008, 02:59 -
I/O Magic DVD ReWritable 16X Drive Not running at 16X
By mmitsch in forum DVD & Blu-ray WritersReplies: 3Last Post: 6th Jul 2007, 23:40
