I aborted a burn of a VIDEO_TS folder to a Verbatim 16x DVD+R (a Data disc burn in RN terms) during the "Verify" stage of the process. I had been sitting at the PC watching it burn and impulsively cancelled during the "verifying" stage, deciding instead to use Nero CD-DVD Speed to scan the disk for errors. Well, the Nero scan did indeed show a couple bad blocks, right at the very end of the disc, and I wonder if it's possible that RecordNow is not "done" writing to the DVD until after it's done verifying. Does anyone know?
It turns-out that while Nero CD-DVD Speed ScanDisc "hangs" at the 92%mark of this disc, it plays fine to-the-end on my PC, and in at least one of my STB players. So I guess the disc is OK after all.
I burned it again, letting RN's "Verify" go all-the-way, and ended-up with RN reporting errors, and there are indeed some bad blocks at the very end of the disc. Very odd, I have never had troubles before w/RN7.3 and Verbatim discs (these are MCC004 IIRC).
I have to question the firmware at this point (using Buffalo 8.57). Hard to imagine I have a bad cake of media... -
bad media sounds like -- try a different brand before anything else
or bad handling ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I made 3 discs in a row at Max speed (16x) which would not verify properly (though the discs were still useable i.e. the bad sectors were at the very end of the movie credit sequence). Then I tried at 12x speed and I got a perfect disc for the first time.
These Verbatims are Inkjet-printable but otherwise show the same as some non-printable 16x I bought (MCC004, both) but the non-printables burned at Max no problem.
I guess I will suffer with this 100-disc cake I bought by burning at 12x from now on.
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 11:24 -
AVStoDVD 2.3.2 - Process aborted during DVD Burning Operations
By Mark97213 in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2010, 14:05 -
Process description.....
By zok4me2000 in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2009, 11:25 -
DvdShrink process stuck after burning to dvd .
By fibola in forum Authoring (DVD)Replies: 8Last Post: 19th Sep 2008, 11:17 -
Any suggestions for getting educated on burning process?
By Cathyq in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 08:44
