Hello guys, I have a question, I have converted couple of mpeg files and burn my first dvd. The problem is when I play this dvd on TV the buttom part is chopping off. There is website logo at the buttom which is not visible on TV. When I play same dvd on PC I am able to view the logo.
Can any one help how I can fix this problem
what is the source footage? What are you using to convert? what are you using to author?
Sounds like aspect ratio is getting a bit messed up somewhere in the process. Most applications will show you what the 'safe zone' is for displaying on a television. -
I am using nero vision express to convert avi, mpeg-1 to dvd format (mpeg-2). There is an option for aspect ratio but I left it on automatic. I have other options that I can pick like 4:3, 16:9 I believe. May be nero vision encoded mpeg in 16:9 format and I do not have 16:9 TV. I have analog 4:3 sony TV. Would that causing the problem. What if I pick 4:3? how it will look on digital 16:9 TV. Thanks in advance
I'm not familiar with nero vision express. My guess is you should select 4:3. A 4:3 encoded file on a 16:9 tv just shows black bars on the left and right...unless the person has their tv set to do something else (like zoom in).
Overscan 101 Course
http://www.uwsp.edu/it/telecomm/utdlr/tutorials/tvgraphics/fortv.htm -
Thanks Guys. So I guess there is no way of getting "Bleed Area" to view on TV.
Would aspect ratio when encoding the mpeg-1 file to mepg-2 help??? there is an option for 4:3 and 16:9 aspect ratio, I originally picked "automatic" when encoded the mpeg-1 files to mepg-2.
May try both 4:3 and 16:9 and see the result. Automatic is not working as it is cutting off the image at the buttom or I would say "Bleed Area"
Thanks. -
Editors, like Premier Pro, allow you to view the 'safe zone' over the footage and then 'scale' down the footage (or scale up)...this would enable you to be sure that your tv will display what you think it will. This of course is just one way of correcting your issue...theirs probably a lot of different (an possibly easier) ways.
Saving view
By jyeh74 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2011, 15:18 -
Camera through computer so I can view on my monitor when in video mode
By Orion1122 in forum Newbie / General discussionsReplies: 0Last Post: 21st Oct 2010, 22:32 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
How can i view my PC on my TV?
By awaisuk in forum Capturing and VCRReplies: 8Last Post: 23rd Jun 2009, 08:24 -
Sansa View 8 GB Model how do I convert video for use with the sansa view?
By goheadtry in forum Video ConversionReplies: 1Last Post: 2nd Jun 2008, 01:01
