So which one is it? If price were no factor, which would be the:
most reliable, fastest, most options, most compatible, most formats, longest-lasting, best support, etc.??
I was really wanting to get a Plextor PX-716AL slot loading drive, but since they seem like they're never actually going to be coming to retailers, I'm looking for something else.
(maybe the PX-740A??)
Results 1 to 21 of 21
most compatible, longest-lasting, best support and reliable would be the pioneer DVR-S201 version 2 hands down .... nothing else comes close ...
Not very fast though ...
$4500 (since you said "If price were no factor")"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
There is no 'best'. There is only what is 'best' for you.
Define what you want to do, how complex you want things to be, how much you are willing to spend and how much effort you are willing to put into this and maybe someone can offer a few suggestions. But even so, there is no 'best'. If there was, all the others would be out of business!Want my help? Ask here! (not via PM!)
i would just get a couple of BenQ DW1640 or DW162x
-- you can't go wrong with those ... just dont use them to burn at 16x IMO (or any burner right now) 4X is fine ... 8X if you are just checking or quick burn required .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Good point.Originally Posted by lordsmurf
So,
I will mostly be using this burner for (in no particular order): backing up, creating DVD reels, video storage, and a bit of authoring.
Really, I just want a really fully-featured, very compatible and solid, reliable burner. I have had VERY good experience with Plextor CD burners, and that's why i was kinda thinking the PX-740A. -
yes the plextors are very good
Originally Posted by DW
The Plextor 740 is a REBADGED BENQ 1640 drive. Plextor does not manufacture the 740. As suggested get the 1620 drive which is so dirt cheap right now. Computergeeks.com has the 1620 OEM on sale during their moonlight madness sales and green light specials. Newegg.com has the drive in stock as well. The prices have fallen because the BENQ 1640 will soon be released in the USA.
I'm getting a bit tired of that PLEXTOR 716AL drive being pushed back every month. I saw the same thing that you did at mwave.com's site. Between the BENQ 1640 & PLEXTOR 716AL depending which drive is the first to be released in the USA will be my next purchase.
Best Buy finally opens up next Friday here in Honolulu, Hawaii. The wait is over.
I would get the Pioneer 109 burners. Then get some good media.
whats the benq1640 going to have for specs?
What We Do In Life, Echoes In Eternity.... -
http://club.cdfreaks.com/showthread.php?t=135093Originally Posted by Denvers Dawgs
check out the PIONEER FORUM at CDFREAKS.COM.Originally Posted by DW
http://club.cdfreaks.com/forumdisplay.php?s=&daysprune=-1&f=87 -
waheed
https://www.videohelp.com/forum/viewtopic.php?p=1325274#1325274
Exactly.It comes down to preference and luck.~Luke~ -
Havn't I seen that somewhere before!Originally Posted by lordsmurf
There are 10 kinds of people in this world. Those that understand binary... -
"Hands-Down Absolute *BEST*" status may last a month at best.
pioneer DVR-S201 been hanging in there for a few years ---
Maybe....Originally Posted by bugster
8)
I have used/owned Pioneer, LiteOn, and Plaxtor burners. I still like
the Plaxtor better. Although the other two are OK. I also heard Pioneer
is better on -R. I used +R most of the time. -
I've owned LiteOn, Sony and Plextor DVD burners. The Plextor is by far the best of what I've owned in every aspect - features, functionality, noise level.
Whatever you go with, make sure it has the features you want (like a drive that supports bitsetting). If nothing else, check out the software packages that come with it, maybe that'll lean you one way.
Tendono-elitritis caused by punching injuries on both hands
By retroborg in forum Off topicReplies: 10Last Post: 1st Sep 2012, 13:23 -
Absolute newb confusion. Buy a digital camera.
By Early Grace in forum Newbie / General discussionsReplies: 6Last Post: 29th Sep 2010, 16:49 -
what's the absolute funniest movie you have ever seen?
By deadrats in forum Off topicReplies: 15Last Post: 7th Jun 2010, 21:13 -
The absolute best method to convert to AppleTV?
By DiGNAN17 in forum Video ConversionReplies: 10Last Post: 26th Aug 2009, 01:05 -
What is the ABSOLUTE BEST quality DVD ripper?
By Saif in forum DVD RippingReplies: 8Last Post: 17th Sep 2007, 20:31
(and DL of course!)
