i have this 2 audio stream divx,
how can i change the default stream ? or disable the other stream?
im looking for a patch or something in 1 hit
i know i could use vdub but...
dont want to have to rewrite the whole damn file
thanks
If you use VirtualDubMod you can DISABLE one audio stream under the STREAMS > "Streams List" tab and then use Direct Stream Copy (under the VIDEO tab) to re-write the entire file WITHOUT the offending audio stream..use the SAVE AS under FILE to save the new file to somewhere on your HD (takes about 2-3mins).
If you just want to PLAY the divx then BSPlayer will allow you to select the audio stream you require (and so will most freeware 3rd party media players)No2: We want Information.
No6: You wont get it!
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
How to change the IE 7 default setting of webpage Save As?
By coody in forum ComputerReplies: 0Last Post: 17th Aug 2009, 13:15 -
TMPGEnc AW 4: default audio stream for different tracks
By reini in forum Authoring (DVD)Replies: 2Last Post: 3rd Apr 2009, 14:33 -
Setting Specific Subtitle Stream -On- by Default.
By GangstaRap in forum Authoring (DVD)Replies: 7Last Post: 16th Jan 2009, 19:50 -
How to change default movie track?
By thomasbbb in forum MacReplies: 1Last Post: 6th Aug 2008, 14:36
