Hi
I am trying to set up a TV as a second monitor, so that I can see what I have edited looks like.
I am using;
Premier Pro 1.5
ADVC 100
XP Home
Leadteck Graphics card with MYVIVO (S-Video & Video IN/OUT).
I have tried all different ways with leads. No Joy.
I have also changed XP Display Properties (dual monitors) etc - still nothing.
I have tried using the AV on the TV/monitor - and also have tuned in a TV channel, hoping to pick up the feed.
Does anyone know where I'm going wrong?
Thanks in advance - regards, Stephen
The problem is the Video card you are using, try with an ASUS Radeon 9200 SE with TV Out and you will be able to work flawlessly.
P.S.
My expensive MSI GForce FX 5700 256 MBs can only work when I shut
down my computer monitor.No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. .. -
The way Premiere Pro is structured, you would use your ADVC-100 (or camcorder) for monitoring your edit. If your project format is DV and the TV is set up for NTSC with 7.5 IRE setup, make sure the sw 2 on the ADVC is set to 7.5 IRE. That will also scale 7.5 IRE captures to correct DV digital levels 16-235.
For other apps, Leadtek should allow normal dual monitor mode in Windows Display Properties. Set S-Video as 2nd monitor. The manual should spell it out.
PS: After writing that I see you are in England, so the ADVC-100 switch should be set to 0.0 IRE.
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
Can't Get My Monitor and HDTV to Work at the Same Time
By wulf109 in forum ComputerReplies: 2Last Post: 6th Jul 2010, 22:36 -
Getting my monitor to work with my mother board
By dnmnbg in forum ComputerReplies: 6Last Post: 6th Mar 2010, 01:33 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
Play video in TV and work in Monitor
By mraza in forum Newbie / General discussionsReplies: 5Last Post: 30th Aug 2008, 19:24
