  1. I convert AVI to SVCD using TMPGEnc Plus (Virtualdubmod for audio).
    After about 50 movies, I've run into a problem with 30fps. I converted the movie, and burned the SVCD, but the video is choppy. I went back and checked the source and found that the AVI itself is choppy. The video info: 503 MB, 868 Kbps, 30.0 fps, 720*432 (16:9), DIV3 = DivX v3 MPEG-4 (Low-Motion), Supported (from AVICodec).
    What can I do? Am I missing a codec? Can I convert 30fps to 29.97fps and use the NTSC setting in TMPGEnc?
    I tried to find an answer on the website, but I can't seem to come up with one.
    "No matter how hard you try, there is always going to be someone more underground than you" - Robert Fulford
  2. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Garbage in = Garbage out
    If your avi is choppy to begin with then you need to find an avi that isn't. You could possibbly do some filtering with avisynth but I doubt it would make any difference.
    Donadagohvi (Cherokee for "Until we meet again")
  3. Member ntscuser's Avatar
    Mar 2003
    Movies should be 24fps not 30fps. Try converting to 29.97fps with TMPEnc set to interlace instead of non-interlace. That will produce a 60Hz video with fewer motion artefacts.
  4. I agree with the garbage in = garbage out idea; usually if my avi is crap then I discard and try again.
    In this case, because the choppiness is so uniform (every 1/2 second) I thought the problem might be codec related, or something I don't know.
    I tried converting to 29.97fps with Interlace, but it didn't work. Could it possibly be codec related, or is it as simple as bad avi = bad svcd?
  5. It's probably as simple as the idiot that created it should have IVTC'd it but didn't. What happens when you open it in VDubMod and advance a frame at a time? Do you see any kind of a pattern?
    And as stated, I don't know what makes you think that by converting it to SVCD that the choppiness is magically going to disappear.
  6. I agree with everyone - I think the avi was done poorly, and so it's been scrapped. I have gotten over the pain of defeat.
    However, I didn't think SVCD conversion would 'magically' fix problems. As I've stated twice before, and now for what is a painfully yet apparently necessary third time, I thought perhaps it was a CODEC thing and not an avi problem.
    Thanks for the useful advice ...
