here's what i managed to do by modifying the the default images menu within divx converter.
unfortunally i couldnt post a screenshot of divxplayer showing the menu because everytime i closed the divxplayer the saved screenshot would go black
i managed to recreat the menu with paint shop pro
its only a very rudimentar menu
anyone heard about a new tool besides fuse to creat divxmenus?
thanks
I love it when a plan comes together!
https://www.videohelp.com/forum/viewtopic.php?t=271697Originally Posted by ricardouk
That's for WMP, but I would think that it would be the same for divxplayer. Try turning overlays offYou may then find that as soon as you close WMP, the image goes completely black, yet when you had WMP open, it looked OK. This is due to a thing called overlays.
If in doubt, Google it. -
cant find overlays function in divx player
thanks for your prompt helpI love it when a plan comes together!
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 03:44 -
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 09:28 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 03:30 -
Need to make test tool to test Dolby
By djai in forum AudioReplies: 0Last Post: 9th Jun 2010, 07:01 -
Test,test amd propus 630
By budz in forum TestReplies: 20Last Post: 1st Jun 2010, 01:46
