I have a few video clips that are 512x384 in size. I want to create a DVD using Adobe Encore DVD 1.5, however it will only accept clips that are 720x480, 720x486, or 704x480.
I also have a copy of Adobe Premiere Pro 7.0, so I was wondering what would be the best way to resize the video clips into the proper format that Encore will accept, preferably using Premiere Pro? Is there a way to pass on a Premiere Pro project to Encore DVD without having to encode with Premier, that way I keep the videos at the best quality possible?
All suggestions would be greatly appreciated.
You will have to reencod somewhere along the line, either in Premiere, Encore, or with a standalone encoder.
You can look up the help files in Premiere for resizing, but it might be as simple as loading the avi into Premiere, then selecting a correct output format. Problem is that Premiere will probably stretch the video and distort it.
Simplest solution - use DivxtoDVD to convert your avi files to DVD, demux them out to video and audio streams, load these into encore to create menus.Read my blog here.
Adobe Encore DVD Question...
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 26th Aug 2011, 06:46 -
Video buttons and background music with Adobe Encore 2
By Doomed Space Marine in forum Authoring (DVD)Replies: 7Last Post: 7th May 2011, 01:10 -
Adobe Encore DVD and subtitles ...
By Liru in forum Authoring (DVD)Replies: 17Last Post: 14th Oct 2010, 17:05 -
Unlink Video and Audio Track Adobe Encore CS4
By LAM_ in forum EditingReplies: 2Last Post: 23rd Oct 2008, 16:51 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 01:09
