    Jul 2004
    Sydney, Australia
    Hi guys,
    For the ages past i have been using DVD Decrypter to decrypt (generally in file mode), then i 'processed' it with Intervideo DVDCopy 3 and burnt it with Nero.
    By the way, my main concern is quality, i don't mind how long the 'processing' takes. However simple software that doesn't require you to rebuild the bugger from the ground up is a bonus for me.
    A few questions:
    1. What other Decrypting utilities work as well as DVD Decrypter did (since it no longer seems to be in development).
    2. When i say 'processing,' was this software encoding or transcoding?
    3. What software can i replace with DVDCopy3 with?
    4. Or should use a totally different method?
    Cheers
  2. 1. None IMHO - DVD FAB DECRYPTER, ANYDVD
    2. TRANSCODING
    3. DVD SHRINK (free) + various payware (NERO Recode)
    4. DVDREBUILDER (w/ HC Encoder OR CCE)
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Encoding a dvd will result in better quality than transcoding but at the expense of time.
