I have 2 large/long avi's that I want to put onto DVD(each) so they are watchable, with a menu if if possible but if its not its no biggie.The files are 4 hours long and just under 2 gig each.I have been using VSO avi to dvd for this kind of thing but once I converted one of the avi's it came out around 9 gigI tried to use DVD shrink but when I pointed it to the video_ts folder it just came up with an error.So would it be possible and if so whats the easiest method to use?
Thanks!!
I'd encode with a MPEG2 Encoder with a lower bitrate and use TMPGEnc DVD Author to make the DVD files.Then if too large use DVDShrink.
Update:I use the Mainconcept MPEG Encoder,it gives you an estimate of the final file size when adjusting the bitrate
Or of course use a bitrate calculator.~Luke~ -
First thing - are your AVIs DivX or XviD ? Do you have a DivX-capable player ? Do you want this playable in all DVD players ?
8 hours on a DVD is really, really stretching things IMO ... you'd need to use 352x240/288, and a bitrate of around 1000kbps (assuming 224kbps audio) to fit on a 4.7GB DVDR.
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm might help you with the conversion process.If in doubt, Google it. -
Heres the stats of my vids, I want to put them on a DVD each(4 hours per DVD)and have them watchable on all DVD players, is this doable?Originally Posted by jimmalenko
Source : DVB-T PCI CARD > MPEG2 > XVID
Resolution : 640*352
Aspect Ratio : 16:9
Video Bitrate : 1015KBPS 2 PASS ENCODE XVID
Audio Bitrate : 160KBPS 48KHTZ STEREO MP3
Filesize : 1.94gb
Filename : T In The Park 2005 (Sunday BBC3).pdtv.xvid-TTT.avi
Capper : TTT -
when i try vso dixvtodvd, it works and it just about doubles the files in to VOB's, it works fairly well and simple xvid/divx to dvd, i wonder why your would get so BIG
Its probably to do with the length of my avis.Originally Posted by kicko
So what do you guys think, is there an easy way of me putting 4 hours of video thats decent(doesnt have to be great)quality onto DVD?
Large MKV split on two DVDs
By bjb39 in forum MacReplies: 2Last Post: 1st Dec 2009, 22:01 -
Question how to put several dvds on one DVDr
By jimdagys in forum Authoring (DVD)Replies: 7Last Post: 24th Nov 2008, 11:29 -
Using nero to put 2 dvds onto 1
By pupa in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2008, 23:14 -
How to put DVDs on Zen Vision: W
By cali_n_alley in forum Portable VideoReplies: 2Last Post: 28th Oct 2007, 20:14 -
Large DVDs won't open
By newtie in forum Authoring (DVD)Replies: 2Last Post: 27th Sep 2007, 20:53
I tried to use
