I have a fresh install of Windows 2000. Up to date video drivers, DX9c, Windows Media Player 9. I downloaded the latest version of the Xvid codec for movie playback, and while the movie will play, the color and contrast are terribly off. I'd compare it to looking at a JPEG with only 16 colors.
What's bizarre is that if I use the FourCC Changer app that comes with the Xvid codec and change the movie's fourcc to Divx, it plays perfectly, even though I have no Divx codec currently installed on my machine
If I *DO* download Divx 6, then the movie plays terribly again, regardless of what FourCC I set it to.
I'm really at a loss to explain what's going on. Any thoughts or suggestions?
You probably have some other MPEG 4 codec installed and only have Xvid set up to decode the Xvid fourcc. When you change the fourcc to Divx the other MPEG 4 decoder is being used.
According to my system, the only codecs I have installed are:You probably have some other MPEG 4 codec installed and only have Xvid set up to decode the Xvid fourcc. When you change the fourcc to Divx the other MPEG 4 decoder is being used.
iccvid.dll
Indeo Video 5.11
ir32_32.dll
msh261.dll
msh263.dll
msrle32.dll
msvidc32.dll
msyuv.dll
XviD MPEG-4 Video Codec
Do you know which of those would be conflicting with XviD?
According to AVIcodec, the movie is an XviD encoded movie, so it should play without a problem.Install Gspot, it will tell everything you need to know about that movie. -
For future reference, this was a video driver problem. Evidentally nVIDIA's latest release, 77.72 causes some kind of "overbright" problem. There's a beta driver out that corrects it.
http://www.nzone.com/object/nzone_downloads_winxp_2k_77.76.html
Extreme Confusion Over Record Format
By 7986andrew in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2011, 01:17 -
Airport extreme router
By Marccc in forum MacReplies: 5Last Post: 19th Nov 2010, 13:01 -
Airport extreme
By Marccc in forum MacReplies: 3Last Post: 26th Oct 2010, 13:30 -
Total Media Extreme Audio De-Sync Problem
By www1221 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2010, 18:35 -
Problems with Decklink HD Extreme
By stunner21 in forum EditingReplies: 1Last Post: 27th Oct 2009, 12:31
