    May 2005
    UK
    does anyone know of a Directshow filter that will take MPEG2 or MPEG4 Transport Stream and render it in Windows Media Player?
    I have tied the elecard (moonlight) one but it adds a 15second delay.
    thanks
    NGN
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    I find the VideoLan viewer works great for TS streams.
    May 2005
    UK
    Thanks edDV
    How do I use VideoLan within Windows Media Player?
    NGN
  4. Member edDV's Avatar
    Mar 2004
    Originally Posted by ngn
    Thanks edDV
    NGN
    That was an instead.
    TS files play fine from WMP here but I'm not sure which of my many installed codecs WMP is using.
    I use "open with" then select wmp10. It responds saying wmp doesn't recognize TS and "Do you want the player to try to play the file?". I say yes and it plays.
