I'm using Vegas to create the MPEG video file to import into DLP, but I've found that the MainConcept MPEG encoder which comes with Vegas is horrible:
Colours are saturated
Quality is really bad as compression artifacts are severe
So what do you recommend I do to get my Vegas project into a format which is compatible with DLP and which will result in really good quality output?
Results 1 to 21 of 21
+--Prince Of Thieves
+--[ DVD Backup Experience =>
+--"I've now ripped a few more coasters!"
well what settings are you using - and what source ?
is this for DVD ?
what has this to do with authoring ? (moving it)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I'm having excellent results, what are you doing in detail from cap to encode?
I'm creating an MPEG file from Vegas using the default settings. The resulting video file is saturated in colour (darker) and has lots of compression artifacts.
What should I change?|
Well, for starters, I bet the bitrate is too low.
How do I check the bitrate of a finished MPEG2 video file?
bitrate viewer. If you saved the project in Vegas the render settings should have been saved as well, so you can check what they were.
Read my blog here.
hit custom and look at the settings -
"saturated in colour" would not be darker .. that would be the result of your settings before encoding , you never did answer what the source was -
For DLP, you will have to adjust IRE to 0 on some sources .. or you may have gone to far and cored the blacks .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I think the default Vegas MPeg2 is VBR 8/6/4.
For highest quality use CBR 8500-9000 Kbps.
Mostly I use VBR 8/7/4 if I want over 60 min per DVD.
There must be something odd about your source material. I'm mostly making DVDs from DV tapes or realtime (Mainconcept) MPeg2 captures at 8/7/4 VBR* and the results are quite good.
* realtime capture is done with ULead Video Studio 8 version of Mainconcept MPeg2 Encoder. -
BJ_M
My material goes this way: DV camera -> HDD via Vegas in AVI format -> Edited and rendered to MPEG using Vegas -> Uploaded into DLP.
Also, when I hit Custom in MPEG1/2, it does nothing.
What's IRE in DLP?
guns1inger
I used the MC standalone last night and made a few changes to the options (I can't remember what they were as I'm at work now), and the resulting MPEG 2 video file looks pretty good!
I think I'm going to have to re-install Vegas to see if that fixes my problem. Thanks all.|
Oops, edited for PAL
It's beginning to sound like you don't have the Vegas MPeg2 encoder properly installed or it has incorrect settings.
What version Vegas?
Have you applied the updates?
Is your project setting "PAL DV (720x576, 25.000 fps)"?
Under "render as" is it set to Mainconcept MPeg2?
Under "custom" have you selected "DVD Architect PAL video stream"?
That gets you 720x576 8000/6000/192 VBR.
If you don't like that try CBR and 8500 Kbps under "video" tab for top quality.
Also, what is your DLP projector model?
What is its native resolution? -
I'm using Vegas 5.0d. Project is Pal DV, rendered as Main Concept MPEG2, and the Custom button does nothing. But, when it DID work, I used the default template.
I think my next step is to reinstal Vegas and see what happens.
Projector? DLP = DVD Lab Pro := DVD authoring software.Also, what is your DLP projector model?
What is its native resolution?|
Gotcha.Originally Posted by thief_
The custom button should work. Lots of controls in there.
Just a note, Mainconcept MPeg2 is an OEM toolkit. Each end developer tweaks it to their needs so expect slightly different performace with the different products (e.g. Adobe Premiere and Encore, Vegas, ULead,etc.). -
dvdlab pro ... oh ...
DLP means something else to me completly ..
yes -- get the custom button working ..
tip of the day -- install the vegas 6 demo and it will upgrade your mpeg encoder to the latest version for your vegas 5 even after removing vegas 6 demo ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Ha ha, I was following this thread because I was curious about compatibility with a DLP projector, and why they wouldn't accept standard DVD input. And maybe see what I'm up against in the future.
My bad.
Same here, I was wondering what could be different for a DLP projector with its little color wheels spinning.Originally Posted by BSR
my DLP projector doesnt have color wheels
hmm, maybe one of those 1960 versions with the greyscale wheel,Originally Posted by BJ_M
Did a search, guess you have 3 seperate DLP chips, one for each color. That isn't a consumer version, is it? Or maybe the price has come down enough, I don't know. -
3 chip
Slow day on Videohelp.com
Looks like they all figured it out.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
Sony Vegas MPEG-2 encoder
By prl in forum Authoring (DVD)Replies: 1Last Post: 3rd Dec 2009, 06:46 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 04:08 -
MainConcept MPEG Encoder 1.5 question
By hanugro in forum Video ConversionReplies: 6Last Post: 21st Feb 2008, 21:27 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 16:56
