Hi I have a 90 minute video ( holiday footage ) that I prepared for a client. The audio didn't come through on his Toshiba home theatre system, so I decided to make another DVD version by extracting the audio and encoding it as AC3 I then re inserted it at the author stage.
The problem is that the video is about 1 - 2 second ahead of the audio.
I'm using ffmpeggui build 3 as the AC3 tool
Any suggestions as to the AC3 settings, if you've had this problem and worked it out would be appreciated.
OR if the clients Toshiba DVD player has a problem with the orignal MPG2 program stream file. What other type of audio can I try ?
PS I'm in PAL land if that makes any difference ?
Results 1 to 1 of 1
Why is an intelligent man's vote, worth the same as an idiot's vote in a democratic election system.
ac3 audio and xvid video in avi out of sync
By socrates in forum Video ConversionReplies: 10Last Post: 15th Jul 2011, 22:58 -
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 01:05 -
AC3 Audio Out Of Sync In MKV
By XiATH in forum Video ConversionReplies: 1Last Post: 24th Jan 2010, 12:09 -
TMPGEnc DVD Author 3 gradually loses audio sync
By timmus in forum Authoring (DVD)Replies: 1Last Post: 6th May 2009, 18:24 -
Capturing AC3 - Stage Two
By Nelson37 in forum AudioReplies: 2Last Post: 11th Nov 2007, 10:01
