I have a problem with the Pioneer DV-440 cutting off the edges of VCDs. It doesn't cut off much, but if there is text, it can be a little annoying. I've simply been burning ANIVCD encodings of various tv shows using Nero. I've set everything to NTSC, so I don't know what the heck's going on. Anyone got an explanation?
ps - this doesn't seem to be a problem with DVDs
I have a similar problem with my pioneer dv-333
When it does it, it cuts the left side off and sometimes put's it on the right side.
I have contacted pioneer and I am waiting for a reply
I saw a VCD that had a similar defect: the image shifted left with a black vertical bar at the right side. But because I saw the VCD on a PC I have no doubt that it is the VCD which was bad. DVD's are better mastered, I guess.
Osprey 440 card capture video in mp4 from live stream
By vrparekh@gmail.com in forum Capturing and VCRReplies: 1Last Post: 13th Apr 2012, 06:21 -
blurred edges
By mathmax in forum RestorationReplies: 50Last Post: 2nd Jun 2010, 11:22 -
Noise around the edges.
By MaiOns in forum Newbie / General discussionsReplies: 8Last Post: 14th Mar 2010, 11:52 -
Jagged edges on buttons
By motown01 in forum Authoring (DVD)Replies: 1Last Post: 21st Oct 2009, 12:40 -
Pioneer DVR-440 or Toshiba XS35 (85DT?)
By StuR in forum DVD & Blu-ray RecordersReplies: 33Last Post: 5th May 2007, 13:38
