VideoReDo will serve the purpose of joining two or MPEG2 files to make a bigger MPEG2 file with absolutey no problem. However, I've a trial version whose trial period expired. Presently, I can't buy a full version of this software. So, guys please suggest me an alternative software to VideoReDo which can also join two or more MPEG2 files to make a larger MPEG2 file. I hope you guys know about the excellent functionality of VideoRedo. So, pls suggest a software whose functionality is same as VideoRedo.
Peretek Simple File Joiner is free...
http://www.peretek.com/sfj.php
MPEG2Schnitt and Cuttermaran are also freeware, but they can only cut and join at I and P frames. I can't think of a frame accurate MPEG2 editor that is free, but MPEG-VCR is fairly inexpensive and works very well. -
thx for the simple file joiner gshelley61...it works great. it's very simple to use and the output is perfect too...all other softwares are just waste.
Looking for a BD Authoring software that dont re-encode MPEG2 Files
By faramith in forum Authoring (Blu-ray)Replies: 11Last Post: 14th Dec 2011, 04:39 -
Software to join .ts(avchd) and .mp4 video files without re-encoding
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Oct 2010, 10:07 -
can't join 2 mpeg2 clips together, need help.
By volam1 in forum EditingReplies: 1Last Post: 25th Apr 2010, 14:02 -
join multiple video files - free software?
By kj1983 in forum EditingReplies: 2Last Post: 21st Aug 2008, 11:54 -
how to join(splice) mpeg2 files without decode them and without artifacts?
By mb508 in forum ProgrammingReplies: 1Last Post: 7th Aug 2007, 06:49
