Results 1 to 9 of 9
  1. I recently aqquired a video file I had been looking for for sometime and to my delight I found the file to be of very high quality (rare on any P2P)
    The file has an embedded duration/frame#/time left counter that is displayed in bold white letters and numbers approximately 1/3 distance down from the top of the current video frame and this counter is displayed from start to finish of the video. it is quite annoying and ruins the entire video despite the video's high quality. I can find no way of removing this counter display except to crop it out. When I do, a full third of the video is cropped out also and this is unacceptable. The upper third of every frame is cut as well as the counter. I use Virtualdub 6.9 and it is apparently unable to remove the offending display.
    Can anyone tell me a way to delete this counter without losing the upper 1/3 of the video?I have been teaching myself video editing for the past 2 yrs and this is the first time I have encountered a file with this cursed counter display so large and positioned in such a way that cropping it out renders the video unwatchable.
    Thanks for any reply and PLEASE help me out here!!
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    What's the title?
    USA
    Virtualdub Logoaway filter will do that, but it won't look that great. They usually put those there during editing 'not for release' video. Or you can put a black bar over it.
  4. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    You are in breach of the forum rules and are being banned. You have been warned about this.
    / Moderator John Q. Publik
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Those are internal "window dubs" intended for offline editing.
  6. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Isn't this similar to this thread:
    https://www.videohelp.com/forum/viewtopic.php?t=273629
  7. gee can I say the title on this forum without getting banned?
  8. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Why not give it a try. :P
  9. no thanks coalmam
