I have an HP laptop. AMD anthlon Mobile XP2500+(1.8ghz). I noticed that in COntrol Panel > System under the system info section it shows the above computer info but shows 516mhz. sometimes it shows the 516mhz then sometimes the 1.8ghz. Is there a setting to make it perform at the 1.8ghz all the time?
Not 100% sure but I think those laptops step down the CPU to whatever it needs to conserve battery power.
thecoalman is correct, but it shouldn't drop down that slow. If you want to eliminate that feature, go to Control Panel >Power Options > and change the Power Scheme to 'Home//Office Desk'. As long a you plan to run on external power this will work. For battery use, though, it won't run too long.
EDIT: My HP laptop has been running a little slow recently and after I typed the above, I checked it. It was set at Portable/Laptop. I guess I need to check it myself once in a while.
yeah mine is set at portable/laptop. When the majority of the time i have the power supply hooked up anyway.
Crap!!!
glad I read this thread. My new laptop seamed fast enough (from my previous desktop) so I was happy enough. Thank you for doubling my speed
Uro -
Glad to help. I found that tip on this site about a year ago, so thanks to the original poster and this site.
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 16:15 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 09:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 19:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2008, 23:56 -
Still Performance
By crocker5731 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Dec 2007, 10:31
