I have created 6 mono racks in Adobe Audition that I need to convert into a 5.1 AC3 file. I have tried BeSweet/BeLight/BeSweetGUI and cannot seem to make it work (I read one post that said the BeSweet MUX facility is not working on the current betas). BeSweet can't seem to read either the 6-channel wavs nor the mono wavs that Audition creates. This is a one-time project, so I really don't want to buy some expensive software (Acid, etc). What are my options? Thanks.
Looks like Vegas 6.0 is your best bet from some of the other posts I've read.
Depending on your needs and budget, you might check out Pinnacle Studio Plus (version 9, I think), with the "Home Theater Edition" packaging -- this supports Dolby Digital 5.1 creator, although I don't know how much "control" one has over the soundtrack production (i.e. it may have much more limited editing than Vegas).
There are a couple of levels of the product, starting at $80, so quite a bit cheaper than Vegas. But again, it depends on what else you need to do; but this might be worth a look. Take a look at www.pinnaclesys.com and see if it'll do ya. Good luck!
Creating a 7.1 Channel MKV with E-AC3/DD+
By JimmyK814 in forum Video ConversionReplies: 4Last Post: 4th Nov 2011, 10:04 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
