Hi I've searched long across this site but I havn't yet found a fair guide for creating a menu and then pasting it into a dvd project...
I have the following apps:
Ulead dvd workshop 2
Dvdremake
Dvd-lab Pro
Do I need more than these applications?
Anyway I would appriciate a guide telling how to do this
Cheers
Results 1 to 11 of 11
im a newbie myself but couldnt you rip your dvd project to elementary streams and then load them up in dvd lab pro and then you can create a menu for it within dvd lab pro?
I love it when a plan comes together! -
You cant easily just drop a new menu into an existing DVD. With a lot of effort you *might* get something like PGCEdit to do it, but the last poster described the quickest option for creating a new menu from scratch.
DVD Remake Pro can help change existing menus, kill buttons, reroute selections etc.Read my blog here.
Well thx for reply,
But here's what confused me: I've seen on many other theards explenations that are including an enourmous guide and anyway, if I do as you said wouldn't the quality fall slightly ? -
I bought it on my evacation last week but realized that it had no menu. Anyway the movie is commercial but this loss of menu can mean that it's homemade eventhough the quality and everything else is in top :S
use dvd decrypter in ifo mode to demultiplex everything you have on the dvd and load then into dvd lab and create a new menu for it.
i think its the best solution to your problem.
YOU CAN EVEN EXPORT YOUR CHAPTER POINTS WHEN U USE DVD DECRYPTER that way u can importthem to dvd lab and have the same chapters as in youroriginal dvdI love it when a plan comes together! -
dvd lab acepts srt,ssa,son and sst subs.
if your sbs are not in this format try to convert them to one of this formats with subtitle workshop.I love it when a plan comes together! -
Actually they are located in the dvd VTS_01 file...that's the problem and I don't know any way to rip it out from there
Need recommended software to edit videos and create a DVD
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 14th Feb 2011, 12:09 -
In GUI Dvd Author-my finished dvd has no sound on the menu in some players?
By extent in forum Authoring (DVD)Replies: 3Last Post: 2nd May 2009, 05:19 -
Which menu to return to when a movie is finished?
By mmasroorali in forum Authoring (DVD)Replies: 3Last Post: 23rd Sep 2008, 09:53 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36 -
Need to add intro video before menu on several finished DVDs
By benracin in forum EditingReplies: 1Last Post: 1st Oct 2007, 12:29
