  1. I own all 3 everybody loves raymond seasons on dvd and would like to copy some to my computer to watch while i'm working. I have win 4 windvd programs that came with my pcchips tv card and of course windows media player 9. How can i copy some shows to my computer?
  2. here's one way:
    http://www.dvd-guides.com/content/view/50/59/
    you may want to try searching the site before posting questions, there are many helpful guides and previously answered questions in the forums that will most likely answer your questions.
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    use either DVD Decrypter or DVDFab Decrypter. Rip to your hard drive and play using windvd.
  4. I downloaded both of them but the copy the disc which makes a problem. I don't want the whole disc just some episodes. Is there a program that will copy i episode as you watch it??
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hi,
    I don't think you can watch while you rip - ripping is MUCH faster than realtime. If you had a capture card you could watch it while you captured it.
    You can use dvdshrink to preview which episodes are which and then use reauthor mode to only rip the ones you want.
    Kevin
    (if you want to leave them on your harddrive try converting them to divx or wmv so it will take less space)
