Hi,
I have XVID videos. The audio is variable bitrate MP3. There 2 tracks audio attached in each video. I want to process these videos using one of the audio track only. If I use VirtualDubMod to open these videos. VirtualDubMod let me to disable audio track that I don't want it. But, VirtualDubMod does not accept variable bitrate MP3. If I use VirtualDub-MP3-Freeze, the variable bitrate MP3 is accepted. But, I don't see stream list menu to select the desired audio track. Is there any solution of the problem?
Thanks,
Kinlun Yu
Results 1 to 1 of 1
How do I find out if my MPEG vidfile has variable bitrate audio?
By cwb in forum EditingReplies: 5Last Post: 22nd Nov 2010, 09:56 -
Need help to set up Variable Bitrate
By spigy in forum Video ConversionReplies: 19Last Post: 16th May 2010, 14:13 -
Error in Variable bitrate (VBR) audio detected
By Russo in forum AudioReplies: 9Last Post: 12th Feb 2010, 09:01 -
Variable Bitrate or Constant Bitrate?
By i am x in forum Video ConversionReplies: 3Last Post: 12th Feb 2010, 08:49 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17
