I'm trying to use Virtualdub 1.3c to extract VBR MP3 audio from an AVI file into a WAV file. Whenever I do, however, the resulting WAV file is only a third or so as long as the corresponding video. Has anyone else run into this problem? Thanks in advance for any trouble-shooting tips you can provide.
Results 1 to 14 of 14
Hi Nikkoforever
Yep, this happened to me so many times with Vdub/VdubMod/any VDub variant that I gave up on using VDub for mp3 to wav conversion YEARS ago...just like your finding now sometimes the full mp3 file would be converted to wav, sometimes just a few minutes and sometimes only one channel (from stereo) slowed to 50% real time.......weird.
Anyway for a quick answer to your problem: either
a) extract the mp3 OR convert the file to wav using AUDACITY or GOLDWAVE...(but this could take up to 20 mins).....if you must
or
b) If you want the audio for a DVD project use FFMPEGGUI to convert the mp3 DIRECTLY to mp2 or Ac3 (use the default 192 bitrate setting) takes about 5mins for a 'typical' 90min .avi......
HTHNo2: We want Information.
No6: You wont get it! -
Originally Posted by monzie
What are you trying to do, convert a DivX;) to DVD? If so, just use AVI2DVD or VSO DivXToDVD v0.5.
Originally Posted by nic2k4
Someone please help me. I'm about to pull my hair out. All I want to do is convert an AVI file with a VBR MP3 audio track into DVD (or separate M2V and WAV files). There's gotta be a program that does this, doesn't there? It doesn't need to be freeware, I'm willing to buy a program. Just point me in the right direction. -
nikkoforever
Are you sure you have the audio in the full processing mode when you extract it?It doesn't matter who you vote for. The government always gets in. -
Originally Posted by Laddydaddy
Have you tried the latest version of VSO DivXToDVD? I know it's not free anymore, but you can use the demo to find out if it'll work, first. They improved it to fix the sync problem.
Check out this thread about correcting sync:
https://www.videohelp.com/forum/viewtopic.php?t=274296
Another thing you could try is converting the audio from the AVI to a WAV with BeSweet. I'm not sure if it can handle DivX AVI's, but it's worth a try. Just compare the playback duration for the video and resulting WAV. You should be able to de-mux the VOB with VOBEdit and get a M2V file you can use in TMPEGEnc. -
Ok the thing to do is convert the file direct from the .avi with FFMPEGGUI (use the default 192 setting and select either AC3 or MP2..personally I would go MP2..purely as I can PREVIEW mp2 audio in my authorer..ac3 is mute until authored). Also BEFORE authoring or anything else CHECK the length (in time) matches your mpv/m2v video file.
If FFMPEGGUI cannot get the correct length in time to match the video then (and it does 99.9999% of the time) then give up NOW as you will be going into serious editing territory (spell?)..and if the project is for work as you say..then let them pay for it....dont let them use you as a 'freebie' ..(read 'idiot').No2: We want Information.
If your within a second then try authoring your DVD......just stick the Vid and audio file in TDA (or your authorer) and check it lines up...use a chapter near the end to check the audio sync.
PS. Is the FFMPEGGUI audio file longer than the GOLDWAVE .wav file?.
FFMPEGGUI starts the audio from when the avi track begins....VDUB/GOLDWAVE etc starts from when the AUDIO track begins within the .avi..these are NOT the same thing (read sentence again if unsure) and here lies most .avi audio probs.No2: We want Information.
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 10:07 -
Exact audio copy refuse to extract to Mp3 now
By Blå_Mocka in forum AudioReplies: 8Last Post: 14th Nov 2010, 04:19 -
How can I extract mp3 audio from .mov container without re-encoding?
By Danteism in forum MacReplies: 16Last Post: 3rd Jul 2010, 04:11 -
question about how to extract mp3 audio from DVD
By jimdagys in forum AudioReplies: 5Last Post: 17th Apr 2008, 10:19 -
Extract audio to WAV using VirtualDubMod
By jimmalenko in forum User guidesReplies: 15Last Post: 14th Nov 2007, 02:42
