l know very little about computers and would like someones help if possible.l have been looking through the forums but am getting even more confused, so if you can help me in simple details that would be great.l have a tosihba a60 super-multi drive ,256mb memory,40gb harddisk,2.80GHz windows xp.l had a holiday disc done,and it,s on a DVD-R but will not play on any of my video recorders,l have downloaded it onto the computers windows media player and it,s in mpg.Will mpg work on video recorders, and can l convert mpg to svcd,vcd,or dvd and how.l also have dv camcorder tapes of previous holiday l would like to put on disks.On the computer is wmm , inter videowindvd creator and roxio easy cd-dvd creator,l,m not sure if any of these will do.Also if l do get up and running with a program how long will a 40 minute tape take to download onto the computer, and how long will it take to burn,as familys would want copys.This DVD-R l got off holiday they had loads done of a 25 minute film in just over a hour, l would be very grateful for answers to these questions. thank you
Hi,
Most dvd players won't read a mpg file. You need to author it to dvd. It is a special structure containing vob files and ifo and bup files.
HERE is some detailed info on what a dvd really is.
You can use programs like tmpgenc dvd author, ulead dvd movie factory, and countless others to make your dvd.
Check out the "how to" section under AUTHORING for more details (on the left of the page)
If it's a DVD compliant video complete with menus most likely your players don't support the -R type disc. You can look to the left for player/disc compatibilities. If it's just a data disc with a mpeg file on it as mentioned by Yoda most standalone DVD players won't play a mpeg file.
Where to go from there depends on what you have, one question at time.Is it a DVD with menus or just a file?
That will make an exact copy on the new disc. Make sure you buy some good discs, another reason why it might not play is because of crap media, media ratings and comments can be found to the left as well. And again look your player up to the left for compatibility.
Even the cheap computer DVD players are more robust than most standalones which is why your computer DVD player can read the disc. -
Yip, what everyone else said. You need to take the mpg and author it as a DVD. In Nero (Roxio is probably similar) just go to make a DVD and add your mpg as a file, Nero will do the rest.
Originally Posted by thevoelk
happy holiday!
By aedipuss in forum Newbie / General discussionsReplies: 12Last Post: 25th Dec 2011, 23:58 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 12:40 -
Holiday Decorations
By vhelp in forum FeedbackReplies: 3Last Post: 28th Dec 2009, 18:40 -
A Holiday Call for Help!
By hexfield in forum DVD & Blu-ray RecordersReplies: 16Last Post: 18th Dec 2007, 20:28 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 10:24
