hi
guys, first time poster long time reader. I like many use cc.covers. but find there covers to be low resolution. I increase the pixels but find a bit of the end cutting off or haveing to cut off a bit of one side so the movie tittle fits on the spine. Can anyone siggest some good (free trial) programs that are gona help me with this problem, maybe even some good quality cover sites.
p.s i like to munch instead of crunch which is why i need a bunch
oooooooooooffffffffff bananas. budun
try using these other free sites, that have Hi-Res covers
http://covers.to/index.php
http://www.hirescovers.com/gallery/thumbnails.php?album=toprated
http://www.dvdcoverart.org/
http://snowscoverland.modblog.com/?show=gallery
Here is a decent site for cover art for the dvd itself
http://www.customcdlabels.com/
Hope these will help you out..What We Do In Life, Echoes In Eternity.... -
One of the problems is that the size of a DVD cover insert often isn't the right size even if the resolution is good. Most of them are scanned and they sometimes aren't trimmed or centered. I load the cover image into Photoshop and first set a reference line down the center of the spine. I then trim the edges if necessary to clean up the rough edges as well as make sure both edges are equidistant from the center reference line. I then use image size and set the exact size - both height and width. This allows you to set the necessary dimensions even if you use DVD cases that aren't the standard 14 mm. thickness. If you don't have Photoshop, many graphics software programs have an image sizing function.
Oh, a side note. Most of these DVD cover images are jpeg files so try to do all of your cleanup, resizing etc. without saving until you have finished making all your changes. Since jpeg files use a compression scheme, each time an image is saved, it is degraded by the compression so if you save it multiple times, you will hurt the quality of the image.
Remuxed mkv using mkvtoolnix leaves file unplayable
By micnolmad in forum Video ConversionReplies: 4Last Post: 10th Jul 2010, 12:33 -
Ripping audio always leaves me with crappy quality
By Nintendo Fan in forum AudioReplies: 20Last Post: 22nd Mar 2010, 19:51 -
LCD TV shows white glow in corners
By Grunberg in forum DVB / IPTVReplies: 5Last Post: 18th Dec 2008, 13:24 -
H.264: how to get good results for objects with round corners...?
By individeo in forum ffmpegX general discussionReplies: 9Last Post: 10th Dec 2007, 09:32 -
DVD to AVI via Fairuse leaves me with amotion problem
By Randall_C in forum DVD RippingReplies: 3Last Post: 3rd Dec 2007, 11:38
