Costco Canada has a coupon right now for 'buy one 50pk spindle, get one free'. They're 50 packs of TDK inkjet printable. Don't know the media code yet. Get 'em while they're hot.
Results 1 to 18 of 18
Where did you see this? I checked the Costco Canada web site, and can't find any mention of it.Originally Posted by dvdashot
Media code are TTG02. The coupon is an in store coupon. Just pick up 2. Hey at 32 cents per disk after taxes, it as about as cheap as generic no names and these are printable (if they burn ok else waste of ink).
The coupon in the US is buy 1 100 pack and get the second for free.
Item 876739 or 876846
Aug 15-Aug 21, 2005
I was considering buying the 37" Sceptre 16:9 HDTV LCD TV for $1699. It has a resolution of 1920x1080, built in tuner and speakers.
Item 896288
You can't beat Costco's return policy -
I'm hoping I can get a pack of -R's and the 2nd +R's...
Got one of each, they're all made in Taiwan, MID for -R is TTG02 and +R is CMC-MAG E01 rev00.
Called them up, said they had 116 spindles of -R in stock. went there 20 minutes later and found none. they told they had made a mistake telling me in the first place that they had -R in stock.
They only had +R in stock and they were made in taiwan, not that if they were made in japan would make any difference. -
I just used a rain check at Costco for dog treats. It was nearly a month after the coupon had expired....
nic2k4
Have you tried them yet? Just went today for a raincheck. I had bad experiences with TDK before but I labelled them all. Not sure about this printable ones. Has anyone tried them? Thanks. -
I've been using printable TDK DVD-R's 8X for at least 10 months now, never a problem.
It looks good in the specs.Originally Posted by dun4cheap
http://www.sceptre.com/Products/LCD/Specifications/spec_X37SV-Naga.htm -
BTW, Sams club has them too, but they are all made in TW
Same here. Haven't had a problem with the printables - which is what's going on sale. I managed to get 2 coupons - will buy my 1st batch and put them in the truck, then go back and buy the 2nd batch. If the wife's with me, she'll stand on another line and buy them.Originally Posted by Robert Simandl
For .22 each, they can't be beat. I use the -Rs and they are excellent: very close to the TYs in Kprobe and Nero quality tests. Absolutely no problems in any of my standalone players, laptops, or desktops.
Verbatim DVD+R 100 pack vs. DVD+R single jewel case
By GSP_87 in forum MediaReplies: 6Last Post: 13th May 2011, 05:00 -
DVDFab Platinum missing 99.9% of DVD, but 100% of it shows in DVD Shrink!??
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 12Last Post: 22nd Oct 2009, 18:31 -
Dazzle Digital Video Creator 100 (DVC 100)
By Rockin Rayzor in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 16:08 -
Costco is Selling New Toshiba DVD Recorder w/DIVX for $130
By peggypwr1 in forum DVD & Blu-ray RecordersReplies: 43Last Post: 5th Feb 2008, 02:13 -
what's the best DVD player in the $100 range?
By j0e in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Sep 2007, 20:26
