im trying to convert a avi file to dvd but having problems.im using dvdsanta the problem is when i add the file the programme freezers up ive tryed different avi files but the same happens.is there a way to check the file, like a player or a different progamme i can try.thanks ,andy
I love it when a plan comes together!
An easy to check a AVI file is to load it into VirtualDub. Then check for errors. It won't tell you everything, but VD usually finds basic errors with AVI files. AVIcodec and Gspot (latest versions) will also give you good information on a AVI file.
Dvd to .avi audio problem
By gartzo in forum Video ConversionReplies: 5Last Post: 21st Feb 2012, 10:04 -
DVD to .avi problem
By poir420 in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2010, 18:12 -
Downloaded AVI to DVD problem
By karlh10 in forum Video ConversionReplies: 6Last Post: 5th Aug 2008, 15:55 -
Avi to DVD problem
By slipknotkod in forum Video ConversionReplies: 2Last Post: 30th Jul 2008, 02:57 -
dvd to avi problem
By hobmob in forum DVD RippingReplies: 7Last Post: 2nd Sep 2007, 18:40
