hi!
i can't play certain videos...
i get a white screen with red lines & text saying:
"can't find vids:divx decompressor"
i have ffdshow installed.
nimo codec pack...
DivXLight Decoder
I love it when a plan comes together!
Codec packs always cause problems. Get rid of Nimo codec pack, ffdshow and DivxLight Decoder. Then download the latest version of the codecs you really need and install them. Probably Xvid (or Divx), MPEG 2, AC3, etc. You may also need the old Divx 3.11 codec for some Divx files.Originally Posted by shernoam
well... i downloaded it...
now i get just black screen (with sound) -
I've had this problem in the past.Once installing codec packs everything gets messed up and even when you uninstall,you have problems.
NEVER install codec packs IMO~Luke~
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2010, 00:05 -
Questions Regarding Video Capturing for "Gameplay" Vids
By cdubya in forum Newbie / General discussionsReplies: 3Last Post: 18th Jul 2010, 19:26 -
"No audio decompressor could be found..." in VirtualDubMod?
By Bix in forum Video ConversionReplies: 5Last Post: 6th Sep 2007, 20:35 -
By Bix in forum Video ConversionReplies: 2Last Post: 6th Sep 2007, 17:18
