Hi, can someone tell me where I'm going wrong? I'm new to video editing and have been working on a project for a job interview collating video footage which I have been editing in After Effects to make a sample movie.
My workflow (just for background info) has been to record video games footage via my standalone DVD Recorder, convert it to Quicktime footage using Cinematize (Mac), import it into After Effects, edit it and render the movie to a 640 x 480 NTSC mov file.
Generally I've been able to get things working fine. I convert the source M2v material using the DVCPRO codec and everything looks OK until I come to use the imported bitmap. It was created in Illustrator and is a centred white logo on a flat black background, exported as a tif and imported into After Effects where it looks great. When I render my movie using the DVCPRO codec the imported video renders fine but the imported bitmap degrades horribly. Alternatively, if I render the movie using the Animaion codec the bitmap is fine but the general quality/compression ratio is poor. Do I have to soften the logo first in Photoshop or apply some filter to get it to render properly?
Can someone advise me? Many thanks.
Thanks for the reply and advice. I solved it this morning just after posting. I reimported the image into Photoshop and applied 0.5% blurring, reimported into After Effects, exported with DVCNTSC codec and it was perfect. Clearly, although my original graphic file was anti aliased it needed a little more softening before being suitable.
Only rendering the first 10 seconds of a 20 minute clip in After Effects?
By kingmustard123 in forum EditingReplies: 4Last Post: 21st Oct 2017, 09:23 -
After Effects rendering produce pixelated video...
By arminio in forum EditingReplies: 7Last Post: 10th Feb 2012, 09:44 -
Help in rendering in After Effects!
By surferadi96 in forum EditingReplies: 5Last Post: 29th Jan 2012, 11:36 -
Rendering Effects in Premiere CS3
By Cherbette in forum EditingReplies: 3Last Post: 20th Sep 2011, 23:47 -
FAST RENDERING of Final Cut Studio Pro and After Effects files.
By Kevin Whelan in forum MacReplies: 3Last Post: 24th Aug 2011, 11:40
