My new panasonic dmr-es10 records using Ac-3 audio.
Do most standalone burners use AC-3 audio?I need a plugin for this to hear the audio on tmpge author 1.6.Can someone explain if this is a good format or not.
Required standard of the DVD format...
https://www.videohelp.com/dvd
Audio:
48000 Hz
32 - 1536 kbps
Up to 8 audio tracks containing DD (Dolby Digital/AC3), DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have DD or PCM Audio. -
Hi,
You can create a ac3 dvd in tmpgenc dvd author. You just can't edit it in tda without the plugin.
Originally Posted by johns0
